Ellabluebird
Interpreting wilcoxon results
can someone help me interpret these results? I just want a double check. If chisq> prob is a p value, then my PIM scores between telemed and telephone are not significantly different. Correct?
Re: Interpreting wilcoxon results
The Chisq > Prob is a p-value. So if the p-value is greater than your alpha, then you fail to reject the null hypothesis of equality. In other words, no statistical difference was found.
Dan Obermiller
