fatemah
Interpreting graph builder fitted lines
I have plotted multiple lines on one plot using Graph Builder (please see attached below). How would I go about interpreting the width of the shaded areas? I have set my confidence interval to 95%.
Re: Interpreting graph builder fitted lines
Did you start a new discussion? Isn't this discussion the same as original discussion?
fatemah
Yes, I am still confused about how to interpret the width of the shaded areas.
I think that starting more than one discussion about the same subject will increase the level of confusion.
