BookmarkSubscribeRSS Feed
paulonis
Jun 4, 2014
Interpreter for JMP formulas?
Is there a way to make use of a JMP formula outside JMP that does not involve SAS or SAS Model Manager?  If I do a linear regression in JMP with continuous variables and then want to make use of that model elsewhere, it's a simple step to put the linear equation into Excel or code it in to just about anything.  However, for something more complicated like using nominal variables in regression or something incredibly complex like a boosted tree (in JMP Pro), making use of the prediction formula outside JMP by translating it into some other "language" is very tedious at best and approaching impossible at worst.  I've seen "Get SAS Data Step for Formula Columns" and "Get MM SAS Data Step for Formula Columns", but this doesn't help if the model needs to be in Excel or any other system that performs calculations.
Unless I'm missing an important feature, JMP does not offer a way to "export" a formula to something common like VBA.  I'm wondering if anyone knows about a third-party solution to interpret a JMP formula and translate input to output through the formula outside of JMP.  Of course, if there is some way that doesn't involve a third-party solution, that would be even better.
I'm not hopeful that anything like this exists, but I'd be incredibly happy to find that it does.  Maybe there is a business opportunity if no solution currently exists.
teebahnson
Jun 4, 2014
Re: Interpreter for JMP formulas?
I also have exactly this problem and I'm still in need of a solution.  It would be so helpful to have the ability to import complex formulas into Excel from the neural networks or boosted tree platforms (or all platforms for that matter).  I tried translating a JMP formula into Excel and was not able to reproduce the results b/c of the model's complexity, my typos, etc.  I Googled/researched solutions for a couple of hours and came up with nothing that worked so I had to result to using a simpler model which was not optimal for my problem.  Any help would be greatly appreciated.
David_Burnham
Jul 13, 2011
Yes it is possible.  I've developed an application that allows a model (e.g. boosted tree or neural net) to be exported and viewed on a web page.  The model is converted from JSL to Javascript.  It could be exported to a language such as VB or C# but because we have to do runtime evaluation it's technically easier to support Javascript since it doesn't require compilation. The application was developed for a client - maybe I should try and encourage them to showcase it at next years Discovery Summit!
David Burnham
-Dave
teebahnson
Jun 4, 2014
Thanks for the reply Dave.  This is great to know.  Sharing this at the Discovery Summit would be very nice.  Otherwise, could you consult for us to produce a similar solution?   thanks, Tee
David_Burnham
Jul 13, 2011
Tee, this is probably not the appropriate forum to have that discussion - let's catch up on LinkedIn.  Dave
-Dave
paulonis
Jun 4, 2014
Nice Dave!  Javascript is certainly a good option for a web application.  The way I'm reading your response is that you did this one time for one client and maybe for just a subset of JSL.  I'm assuming that you don't have anything for general sale.  Correct?  Have you considered making this a product?
