robinson
Interactively select a column to perform an operation (say Log of a column) and place results in a new column using JSL
I am trying use JSL to interactively choose a column from a DT perform an operation on that column and place in a new column. I cannot get the syntax correct to execute the operation.  Enclosed is my script and a sample DT.
ms
Super User ms
Re: Interactively select a column to perform an operation (say Log of a column) and place results in a new column using JSL
It can be tricky to pull a column from a dialog and put into a column formula.
Here is one way to do it, based on your example:
cdlg = Column Dialog(sel = ColList("Select Col", MinCol(1), MaxCol(1)));
f = Eval Expr(Log(Expr(cdlg["sel"][1])));
szz = cdlg["sel"][1] << get name;
dt << New Column("Log of " || szz, numeric, continuous, formula(Name Expr(f)));
ms
Super User ms
robinson
Works Great. Much Appreciated
Article Labels
