It’s World Statistics Day! To honor the theme of the day, the JMP User Community is having conversations about the importance of trust in statistics and data. And we want to hear from you! Tell us the steps you take to ensure that your data is trustworthy.
robinson
Interactively select a column to perform an operation (say Log of a column) and place results in a new column using JSL
I am trying use JSL to interactively choose a column from a DT perform an operation on that column and place in a new column. I cannot get the syntax correct to execute the operation.  Enclosed is my script and a sample DT.
ms
Super User ms
Re: Interactively select a column to perform an operation (say Log of a column) and place results in a new column using JSL
It can be tricky to pull a column from a dialog and put into a column formula.
Here is one way to do it, based on your example:
cdlg = Column Dialog(sel = ColList("Select Col", MinCol(1), MaxCol(1)));
f = Eval Expr(Log(Expr(cdlg["sel"][1])));
szz = cdlg["sel"][1] << get name;
dt << New Column("Log of " || szz, numeric, continuous, formula(Name Expr(f)));
ms
Super User ms
robinson
Works Great. Much Appreciated
Article Labels
