Ann_JMP_User
Inserting a self-defined formula in JMP script
Hi all,
I am actually looking into inserting a formula in the script for every Row available with data, after obtaining the mean of M1-M7 in the summary table.
But somehow, I'm always being prompted with error while debugging. Is there anyway that I can do this better ?
Re: Inserting a self-defined formula in JMP script
The new column syntax is in error.  It should be:
FE = dt2 << New Column( "FE",
     Numeric,
     Continuous,
     Width( 5 ),
     Formula( :M7 - ( :M3 - :M1 - Z ) )
     Numeric,
     Continuous,
     Width( 5 ),
Ann_JMP_User
Thank you very much for pointing this out, Jim.
