Daniel_Lea
Insert list of column names into a formula
I am making a script creating about 14 different journals.  I have maybe 10 different sets of data that am going to prepare and for each for each journal I would like to update specific data from other tables and then also chart the specific data.   The chart settings for my script are more complicated than the sample script I supplied.  Please help me figure out how use a variable for the column names in my script.  I've tried a bunch of combinations of Parse, eval and expr and couldn't get it to work
Would like to do something like this:
table1 = open("$SAMPLE_DATA/students1.jmp");
table2 = open("$SAMPLE_DATA/students2.jmp");
ins = ":height, :weight";
table1 << Update(With( table2 ),
Match Columns( :name = :name ),
Add Columns from Update table( parse(ins) ));
Current Data Table(table1);
Scatterplot Matrix(
	Y( parse(ins) ),
	X( :sex ),
	Matrix Format( "Lower Triangular" ),
	Ellipse Color( 3 ),
	Fit Line( 0 )
and result I would like to be like this:
Add Columns from Update table( :height, :weight ));
Scatterplot Matrix(
	Y( :height, :weight ),
	X( :sex ),
	Ellipse Color( 3 ),
	Fit Line( 0 )
Re: Insert list of column names into a formula
Here is an old school way of handling your issue
names default to here(1);
ins = ":height, :weight;";
eval(parse(
"table1 << Update(With( table2 ),
Add Columns from Update table( "||ins||" ));"));
Scatterplot Matrix(
	Y( parse(ins) ),
	X( :sex ),
	Ellipse Color( 3 ),
	Fit Line( 0 )
eval(parse(
Scatterplot Matrix(
	Y( parse(ins) ),
	X( :sex ),
	Ellipse Color( 3 ),
	Fit Line( 0 )
Daniel_Lea
Hi Jim,
How would I do the scatter plot using the same method?  One of the scatterplot parameters has quotation marks.  Thanks!
\! is the escape sequence in JMP, therefore, as can be seen in the below script, \!" is used to embedd a double quote in a quoted string
theExpr = (
"Bivariate( Y( :height ), X( :weight ),
Where( :sex == \!"F\!" ) );"
eval(Parse(theExpr));
All of this is covered in the Scripting Guide.  I strongly recommend tthat you take the time to read it.
     Help==>Books==>Scripting Guide
Daniel_Lea
Thank You
