Gadsdon
Individual control chart retaining batch number and using filter
Hi I see there are two facilities for generating Individual control charts
1) Via the Control Chart Builder (Analyze/Quality and Process/Control Chart Builder)
2) Via the I (Analyze/Quality and Process/Control Chart/IR)
Can the Control Chart Builder retain batch number - all I seem to get is a continuous number 1,2,3,4, ....etc?
If I select the IR method I can select the batch number via the "Sample Label"
The second part of this question relates to filtering.  The Local Data Filter is present in the Control Chart Builder but am I correct that it is not present in the IR method ? is there a reason for this
Cheers Ian
Gadsdon
Re: Individual control chart retaining batch number and using filter
I found the solution to changing the consecutive numbers of 1,2,3 ..etc to an alpha numeric batch number.
Step#1        Step#2 - choose the followiung settings "List Check" is the key "Column Properties"
Gadsdon
Gadsdon
But still need help with the second part of the question
You can use a Global Data Filter, placed on the Data Table.  Go to the data table the Control Chart has been constructed from and then go to
     Rows==>Data Filter
A Global Filter will change all platforms that are open for the data table.  If this is an issue, then just create a subset of the data table, and use the new subset to run the control chart on.
