Including all rows when splitting
jamiesupica0
Jul 15, 2016
I have a dataset where class is broken into "Initial" and "Refined" groups.  There are also subclasses within each group...
I want to split the table so the two groups are in two different columns like so
However, when I tried splitting the table as shown below I only get one instance of each Item Class.
Question:  How can I split this table so that all values are represented?
Jun 22, 2012
You can do it by adding a new Grouping column, which allows the matching of the Subclass levels(number).  I just added a new column "Column 4" and gave it the formula:
Right(:Subclass, 1)
I then used it in the Tables==>Split platform
and got the results data table
jamiesupica0
Jul 15, 2016
Thanks so much for your response Jim.
Unfortunately this workaround won't get what I need.  There are 5000+ rows in the dataset and the Subclasses are all characters (the numbers I included were as an example only).
I might be able to fenagle an index column to achieve your example below but I was hoping I was just overlooking a box that needed to be checked.
My JSL writing skills are limited so don't waste your time coming up with a lengthy code snippit as a solution :)
Thanks again.
Jun 22, 2012
I assumed the Right() function would not be the miracle cure for your problem.  The point of the extra column is simply to just come up with a column that allows for the grouping requried for your data.  If you think in those terms, you may find a simple solution in your data.
