BookmarkSubscribeRSS Feed
msharp
Jul 28, 2015
In()
In SQL there is a command for in(..) where it will find every row in a table that the column specified has a value IN the in(...) statement.  This is nice to quickly find items in a list.  It would be nice if we could do this in JSL.
EX:
dt << Select Where( in(col, list) );
as opposed to:
dt << Select Where( :col == list[1] | :col == list[2] | ... )
The disadvantage for the second method is obvious that you would require knowing the length of the list.
I can think of several work arounds with for loops, but most of these will run into performance issues in large data sets.
Just add this to my wish list.
Jun 22, 2012
Re: In()
dt<<select where(N Rows(Loc(list,:col))>0);
This should do what you want
ms
Jun 23, 2011
Re: In()
This simpler version of the same idea works too (Select Where apparently treats [1] as True and [ ] as False):
dt << select where(Loc(list, :col));
msharp
Jul 28, 2015
Re: In()
Thank you!  After a few minutes I finally understand.  Instead of searching the column for the values in the list, we are searching the list for the value found in each cell.
ms
Jun 23, 2011
Re: In()
Contains() may do what you wish.
list = {"JANE", "ALICE", "MICHAEL", "ELIZABETH"};
col = Column(dt, "name");
dt << select where(Contains(list, col[]));
