BookmarkSubscribeRSS Feed
xiaoyaj0
Apr 25, 2016
In nominal logistic model, how to set comparison group?
In the DV, I have six categories, and JMP default Group 6 as the comparison group. I would like to change the comparison group to Group 5. Could somebody help me?
I am predicting educational plan from student achievement.
Thank you so much!
ron_horne
Jun 23, 2011
Solution
Re: In nominal logistic model, how to set comparison group?
hi xiaoyaj0​,
just go to the column info and change the value ordering. JMP will always use the last category as the comparison group.
good luck and good night!
Ron
ron_horne
Jun 23, 2011
Solution
hi xiaoyaj0​,
Ron
xiaoyaj0
Apr 25, 2016
Thank you so much, Ron. That definitely solved the problem! Have a good weekend!
