BookmarkSubscribeRSS Feed
agneshb
Jan 19, 2014
In cube plots, is there a way to change the number of digits that are displayed?
In DoE data analysis I use the cube plots a lot but could not find a way to modify the number of digits displayed in each corner of the cube (it will display 30.4354 when I only want 30 to be displayed).
Does anyone know how to change that?
Thanks!
Jun 22, 2012
Re: In cube plots, is there a way to change the number of digits that are displayed?
The cube plot is a picture image, so it is not directly manipuable.  I tried changing the format of the independent variable, but it had no effect.  I assume what you see is what you get, when it concerns the cube plot.
agneshb
Jan 19, 2014
Thank you, that's what I thought...
Is there a way to change that using the saved script for the model?
