gene
In JSL I want to copy the data from a named group of columns to another table with the same size named group of columns.
I have two tables.  Each has a named group of columns.  I want to copy the data from the Source Spectra table, from the group named "source"  to the Target Spectra table in the column group target.  I need to do this with JSL.
pmroz
Re: In JSL I want to copy the data from a named group of columns to another table with the same size named group of columns.
This is one way to do it:
dts = data table("Source Spectra");
dtt = data table("Target Spectra");
dts_cols = dts << get column names(string);
for (i = 1, i <= nitems(dts_cols), i++,
     one_column = dts_cols[i];
     dts_values = column(dts, one_column) << get values;
     new_column = substitute(one_column, "Column", "target");
     column(dtt, new_column) << set values(dts_values);
ms
Super User ms
There's usually more than one way to do it in JMP...
dts = Data Table("Source Spectra");
dtt = Data Table("Target Spectra");
dts << Bring Window To Front << Clear Column Selection << clear select << select column group("source");
Main Menu("Copy");
dtt << Bring Window To Front << Clear Column Selection << clear select << select column group("target");
Main Menu("Paste");
