BookmarkSubscribeRSS Feed
agseedsbrett
Apr 16, 2013
Importing from Excel
I am inporting a file from excel to JMP, where i have numerous columns hidden and numerous rows filtered.  I have unchecked import hidden rows and columns. When i click data table in thethe JMP add in on excel it does not import the last 3 of 18 visible columns.  I know it did import all columns at one point, have i inadvertenly checked or unchecked a box somewhere?
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: Importing from Excel
Hi Brett,
Only the data that you have selected in Excel is transferred to JMP when you use the JMP Add-in for Microsoft Excel.
Did you have all the rows and columns that you want in JMP selected when you hit the Data Table button?
-Jeff
-Jeff
agseedsbrett
Apr 16, 2013
Jeff-
I have tried to highlight just the columns and rows that i need to import to JMP but it is still leaving out the final 2 columns.  I will try it again to verify that is the case.  I seem to remember that when i first started with JMP i was able to import the whole sheet.
Brett
Jeff_Perkinson
Community Manager
Jun 23, 2011
Hi Brett,
If you continue to have difficulty, contact JMP Tech Support. They can help figure out what's going wrong.
-Jeff
-Jeff
