JensRiege
Import .dif file format in JMP Script
I am trying to import a .dif text file into a JMP data table.
When I use the file import, I have the option of using Excel to open it, or "Data with Preview".
If I were to write a script to use Excel to open it, how do I get the same script to put the excel worksheet into a JMP table for further use.
I would prefer not to have to use an external program to open it, but if I use Data with Preview, it puts all data into just one column in the .dif file format structure:
Header 1
Value1, Value 2
Header 2
Value3, Value 4,
etc.
Is there a way for JMP to open .dif files directly in the same table structure that Excel creates?
Thank you for any help you can provide.
Jens
stan_koprowski
Re: Import .dif file format in JMP Script
Hi @JensRiege ,
I created an add-in to import data interchange format (DIF).
Have a look and let me know if this will work for your files.
cheers,
Stan
cwillden
Maybe you could parse it if you read it in as plain text?  I'm not sure what the file contents look like in a dif file.
-- Cameron Willden
JensRiege
Thanks for replying cwillden.
Attached are what the file looks like if I try to open it in Plain text format and with "Data Using Text Import Preferences"
All text is in column 1 in separate rows, and numbers are in first and second column) Plain Text.pngData Using Text Import Preferences.png
stan_koprowski
Hi @JensRiege ,
cheers,
Stan
JensRiege
Replied privately, but wanted to make sure this forum got the feedback. Solution works very well. I modified the Add-in to allow the code to be used within a JMP script file.  I am using this code daily now for production requirements. Thank you!
