Swalo66
IR chart issues
All Data IR ChartAll Data IR ChartAll data with filterAll data with filterAll data with filter re-run from platformAll data with filter re-run from platformSubset dataSubset dataWe have large datasets that have a "grade_code" variable that use use as the phase for various SPC.  If we use the main (complete) datafile you can see the IR chart result (AllDataIRchart.jpg), if I the run a grade filter the chart updates and produces Alldatawithfilter.jpg.  If this filter is kept in place and the IR chart re-run from the platform I get Alldatawithfilterre-runfromplatform.jpg.  I I create a subset file and then run the IR chart I get Subsetdata.jpg.
In previous version of JMP (11 or so I think), running the filter on the main table would produce IR charts that don't have the "gaps" an looked directly like Subsetdata.jpg WITHOUT having to actually create a subset file.
Where has this capability gone??
Re: IR chart issues
If you switch to using Control Chart Builder for your IR chart, you can use the option "Show Excluded Region" to eliminate the gaps.
Re: IR chart issues
Swalo66
Re: IR chart issues
PERFECT!! THANKS
