BookmarkSubscribeRSS Feed
sfkeydel
Jun 23, 2011
I would like to use the Recode grouping functionality on Date columns
As the title states, I would like to use the Recode grouping functionality on Date columns. I'm often wanting to group single dates into fiscal year attributes (FY16Q1, for example), and while I can accomplish the same thing with a formula, it would be a lot more convenient to be able to do this in a Recode operation.
Am I missing a simple way to access this functionality within Recode, or should I open a feature request?
Thanks,
Stefan
Jun 22, 2012
Re: I would like to use the Recode grouping functionality on Date columns
You can get some of the functionality you want by changing the format of you date columns to yyyyQq,  But it is not a total solution.  So I suggest that you put in a feature request to:
     support@jmp.com
