BookmarkSubscribeRSS Feed
qacc
Not applicable
Jun 9, 2014
I need to fix Upper control limit for particulate matter rejects based on results of 20 to 30 batches, I am following quantile approach with 0.99865% as upper limit. data is non normal distributed hence I used smooth curve fit in SAS. could any one tell m
I need to fix Upper control limit for particulate matter rejects based on results of 20 to 30 batches, I am following quantile approach with 0.99865% as upper limit. data is non normal distributed hence I used smooth curve fit in SAS. could any one tell me is this the right approach?
Regards
Raghunandan
