BookmarkSubscribeRSS Feed
tanya_davis
Community Member
Jun 14, 2016
I am trying to set DOE for experiment where I want to test the order of adding materials together.
Steven_Moore
Jun 4, 2014
Re: I am trying to set DOE for experiment where I want to test the order of adding materials together.
Tanya,  I would set up the experiments this way:
Suppose you have 3 components, A, B, and C.  There are 6 ways to add the components:  ABC, ACB, BAC, BCA, CAB, CBA.  I am assuming you will be using the same amounts and concentrations here.  You can then repeat the experiments in random order or two or three replicates.  You can then analyze the data using ANOVA techniques to determine the best order.  You can then optimize for amounts and concentrations using the Definitive Screening Design.  This is pretty simplified, but I think it will help you get a start.
Steve
