crzyny1
I am trying to rename the coulmn 3 times in my script and it only works for the first time but does not work after. I am using JMP11.
col
= column("VALUE")
col
<< set name("VALUE_orig")
Data Table
( "Map data" ) << newcolumn("VALUE", numeric, continuous, formula(abs(:VALUE_orig)))
col
= column("VALUE")
col
<< set name("VALUE_nonlog")
col
= column("VALUE_trans")
col
<< set name("VALUE")
Any suggestion?
Craige_Hales
Staff (Retired)
Re: I am trying to rename the coulmn 3 times in my script and it only works for the first time but does not work after. I am using JMP11.
Check the JMP Log window for messages.
If there is more than one table open, make sure to specify the table:
dtBC=open("$sample_data/big class.jmp");
dtCP=open("$sample_data/car poll.jmp");
bcsex = column( dtBC, "sex" );
cpsex = column( dtCP, "sex" );
bcsex[2] = "f";
cpsex[2] = "m";
Both tables contain a "sex" column.  Data table variables are created in lines 1 and 2.  The data table is explicitly specified in lines 4 and 5.  Lines 7 and 8 modify the columns in the corresponding tables.
Craige
