BookmarkSubscribe
mpg
mpg
Re: How would you improve the Formula Editor?
1) When I was first learning JSL I would use the formula editor to guide some of my script, would have been nice to have a "save formula script to script window" option.
2) If a task can be accomplished by more than one function, after the user creates one version, could JMP recommend alternatives?
Hegedus
One of the most useful functions, I find is "Match" and ability to auto populate with values in a column is great.  It usually takes 4-5 tries to get the exact sequence of keystrokes with correct modifiers to work.  I would love to see that one made a bit easier.
shoffmeister
I guess it's more a power-user thing, but I struggle from time to time with some functions that use multiple arguments but the arguments are not named.
Example:
Using the "word" function in the "character"-section there are the names of the arguments displayed in gray inside the boxes (n and text).
This is not the case for the "substitute" function.
It would be great if all functions displayed the argument names.
shoffmeister
Another thing: Whenever I need to calculate the square of something I intuitively press the "^"-button on my keyboard.
The formula editor automatically makes this out of it: (:X ^ 2) ^ 2
My expectation would be :X^2 only.
And yes: I am pressing the "^"-key only once ;-)
Jeff_Perkinson
That does sound like it would be annoying, however, I'm unable to reproduce that behavior. It happens every time?
Is anyone else seeing that?
-Jeff
-Jeff
shoffmeister
Hi Jeff,
it is constantly happening on my system. But it might be due to my setup (using Windows 7 in paralells on a Mac).
Sebastian
ron_horne
i get the same using Jmp11
msharp
I can't replicate the "^" effect either.  I only get X^2.
edzard_van_sant
1. First of all, making the default formula user interface larger would be a big step. I don't believe that size hasn't changed since ancient times even though nowadays screens are larger and/or have a much higher resolution.
2. I really like the suggestions of having JMP assemble the formula from individual columns. I usually have student test individual components of a larger formula before assembling the final product.
3. Give the user the option in preferences to select function groups he/she most often uses.That would cut down on the clutter. In the process of creating that capability you could create more function groups. For teaching it would really help if students didn't have to wade through the muck of 100+ functions to get to the one they really need.
ajbalak
I'm not yet a regular user, so this may already be available. I wish there was some kind of hotkey to launch the formula editor. Say, select the column and hit '='. I've always found the 2-3 mouse clicks it takes to get to the formula editor slightly annoying.
