Victor60
How would I best exclude thousands of rows of data based on a single column showing a value to be an outlier?
1.2 million rows x 16 columns
Column for ambient temperature shows many observations (by day) that were classified as outliers, above the box and whisker top tail in the graph builder.  This is unfortunate, but likely due to the placement of the ambient temperature measurement probe on a moving vehicle.
Goal is to properly ID and suppress rows of data having ambient temperature outliers, before using a neural network to model the data to compare performance of widget A to widget B.
I've read a few threads here, but cannot find a similar question with solution.
Re: How would I best exclude thousands of rows of data based on a single column showing a value to be an outlier?
Easy-peezy
Bring up your outlier box
Drag your cursor over all of the outlier points which will select all of them in your data table.
Now go to the RowState column in your data table and go to one of the rows that has been selected.
While hovering on the selected row, right click on your mouse and select "Exclude"
All selected rows will be Excluded
You may want to select Hide and Exclude
ron_horne
Hi @Victor60
i have once written a script that earmarks rows if they are outliers in any of the groups in any of the variables. i have updated it to include different days in once column and a couple of columns of temperature. it produces a new binary column indicating outliers for each original column and one more indicating whether the observation is an outlier in any of the variables.
lets us know if it works.
ron
// make a sample data table
dt = New Table( "Data",
	add rows( 10000 ),
	New Column( "it", Numeric, Ordinal, Format( "Best", 8 ), Formula( Row() ) ),
	New Column( "Day", Numeric, Ordinal, Format( "Best", 8 ), formula( Random Integer( 110 ) ) ),
	New Column( "temp1", Numeric, Continues, Format( "Best", 8 ), formula( Random Lognormal( :Day / 10, 5 ) ) ),
	New Column( "temp2", Numeric, Continues, Format( "Best", 8 ), formula( Random Lognormal( :Day / 10, 5 ) ) ),
	New Column( "Out",
		Numeric,
		Ordinal,
		Set Property( "Value Colors", {0 = -13977687, 1 = -4222943} ),
		Color Cell by Value,
		formula( 0 )
	New Column( "Outtemp1",
		Numeric,
		Ordinal,
		formula( 0 )
	New Column( "Outtemp2",
		Numeric,
		Ordinal,
		formula( 0 )
dt << run formulas;
Column( dt, "it" ) << delete formula;
Column( dt, "Day" ) << delete formula;
Column( dt, "temp1" ) << delete formula;
Column( dt, "temp2" ) << delete formula;
Column( dt, "Out" ) << delete formula;
Column( dt, "Outtemp1" ) << delete formula;
Column( dt, "Outtemp2" ) << delete formula;
// now we get to work
// make a list of days
byvarlist = Associative Array( dt:Day ) << get keys;
// make a list of columns
cols = dt << get column names( Continuous ); //List all Numeric columns
// loop through the days
For( i = 1, i <= N Items( byvarlist ), i++,
// select each Day
	dt << select where( dt:Day == byvarlist[i] );
// subset each Day
	subdt = dt << Subset( Selected Rows( 1 ) );
// clear selection for smooth workflow
	dt << clear select;
// fined outliers in each variable within each Day
	For( ii = 1, ii <= N Items( cols ), ii++,
		out = Eval(
			Parse(
				"subdt << get rows where(
	subdt:" || Char( cols[ii] ) || " > Col Quantile( subdt:" || Char( cols[ii] ) ||
				", 0.75 ) + 1.5 * (Col Quantile( subdt:" || Char( cols[ii] ) || ", 0.75 ) - Col Quantile( subdt:" || Char( cols[ii] ) ||
				", 0.25 )) | subdt:" || Char( cols[ii] ) || " <
				", 0.25 ) - 1.5 * (Col Quantile( subdt:" || Char( cols[ii] ) || ", 0.75 ) - Col Quantile( subdt:" || Char( cols[ii] ) ||
				", 0.25 )));"
		Eval( Parse( "column (subdt, \!"Out" || Char( cols[ii] || "\!" )[" || Char( out ) || "] = 1;" ) ) );
	// also indicate the global outlier
		Column( subdt, "Out" )[out] = 1;
		//wait (0.00001);
// update original data table with new information for the Day
	subdt << delete columns( "Day" );
	subdt << delete columns( cols );
	dt << Update( With( subdt ), Match Columns( :it = :it ) );
	Close( subdt, No Save );
	//Wait( 0.00001 );
dt << color by column( :Out );
Byron_JMP
I'd like to suggest a little different approach.
Maybe try scripting the Explore Outliers platform, like this:
dt=current data table();
obj=dt<<Explore Outliers( Y( :DATA_COLUMN ), Q( 0.5 ), Quantile Range Outliers , Show only columns with outliers( 1 ) ); obj << Exclude rows( :DATA_COLUMN );
To set this up, use the Explore Outliers platform to get your conditions nailed down, then just save the script to the script window.
Substitute your conditions for mine, and you're good to go.
You could also, just select the outliers, then invert the selection and then make a subset of the data you want to keep.
JMP Systems Engineer, Pharm and BioPharm Sciences
Victor60
Amazing. Thanks for insights.
Victor60
Wow! Thanks for the education!
