BookmarkSubscribeRSS Feed
poulravn
Community Trekker
How to write a compact list of numbered column names?
I have a data table, which has a large number of column with names: v1, v2, v3, v4, v5 etc. Going up to more than v200. I want to do a 'stack' of these colums:
newtable= Data Table( "oldtable" ) << Stack(Output Table("newtable")
,columns(:v1,:v2,:v3,:v4,:v5,:v6,:v7,:v8,:v9,:v10 etc. . . .
Is there a simple notation for listing all variables with the same prefix? Like v1-v10? So that I can avoid writing all the individual names?
Regards
Poul
pmroz
Re: How to write a compact list of numbered column names?
Here's one way to do it.  You build an expression and execute it via eval(parse()).
old_dt = New Table( "oldtable",
    Add Rows( 2 ),
    New Column( "v1", Numeric, Continuous, Format( "Best", 12 ), Set Values( [1, 6] )),
    New Column( "v2", Numeric, Continuous, Format( "Best", 12 ), Set Values( [2, 7] )),
    New Column( "v3", Numeric, Continuous, Format( "Best", 12 ), Set Values( [3, 8] )),
    New Column( "v4", Numeric, Continuous, Format( "Best", 12 ), Set Values( [4, 9] )),
    New Column( "v5", Numeric, Continuous, Format( "Best", 12 ), Set Values( [5, 10] ))
col_names = old_dt << get column names(string);
for (i = 1, i <= nitems(col_names), i++,
    if (i == 1,
        col_string = "columns(:" || col_names[i];
        col_string = col_string || ", :" || col_names[i];
col_string = col_string || ")";
stack_expr = evalinsert(
"\[new_dt = old_dt << Stack(
    ^col_string^,
    Source Label Column( "Label" ),
    Stacked Data Column( "Data" ),
    Output Table( "newtable" )
eval(parse(stack_expr));
ursula_garczare
Community Trekker
Actually, I just had a rather similar problem and it is not necessary to go via the parsing route. I  just was very stubborn in wanting to avoid that and was lucky in finding an alternative:
Building up on the example above, the statement below shoul also work (JMP Pro 11.1). The trick is the [1::length(col_names)] in the stack statement!
  Add Rows( 2 ),
  columns(col_names[1::length(col_names)]),
pmroz
Hmm nice solution.  Turns out you can remove the 1..length as well.  This works:
  columns(col_names),
dkeshock
Community Trekker
Do you know if the original table contains only 'v#' columns?
Col_Names_Full = old_dt<<Get Column Names(string);
Cols = N Cols(old_dt);
Col_Names_Stack = List();
Counter = 1;
For(i=1, i<=Cols, i++,
      If(Starts With(Col_Names_Full[i], "v"),
            Col_Names_Stack[Counter]= Col_Names_Full[i];
            Counter= Counter + 1,
            empty(),
columns(Col_Names_Stack),
