    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
mvanderaa1
How to use the value of my For Each loop to generate new table scripts
I am looping over existing data table scripts and creating a duplicate of each script with some alterations.
I want to insert those table script names into the generated table scripts.
The output I get just inserts the word "script" in my generated table scripts instead of the actual string value in scriptList
scriptList = dt << Get Table Script Names;
For Each({script}, scriptList,
	If ((!Contains(scriptList, "Run "||script)),
		dt << New Script("Run "||script,dt=Current DataTable();w=eval(dt << get table property((script)));w << set window title((script)));
Re: How to use the value of my For Each loop to generate new table scripts
Some expression handling combined with Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute should work. Here is one example:
For Each({script_name}, dt << Get Table Script Names,
	If((!Contains(script_name, "Run " || script_name)),
		script_expr = dt << Get Script(script_name);
		Eval(Substitute(
			Expr(
				dt << New Script("Run " || _script_name_,
					Local({w},
						w = _new_script_;
						w << set window title(_script_name_)
			Expr(_script_name_), script_name,
			Expr(_new_script_), Name Expr(script_expr)
		Eval(Substitute(
			Expr(
					Local({w},
						w = _new_script_;
mvanderaa1
thank you that is indeed working nicely
mvanderaa1
Hi, I guess I didn't specify as such in my original question, but your solution did change the behaviour of my script since it copies the target script code into the new script. I wanted to keep the reference only to the original script. Here's the final script I'm using, maybe other people might find it useful.
dt = Current Data Table();
For Each( {script_name}, scriptList,
	If( (!Contains( script_name, "Run" ) & !Contains( scriptList, "Run " || script_name )),
		Eval(
			Substitute(
					Expr(
						dt << New Script(
							"Run " || script_name,
							w = Eval( dt << get table property( script_placeholder ) );
							w << set window title( script_placeholder );
				Expr(script_placeholder), Char(script_name)
lala
Level IX
JMP 14 no work.
For Each() function is a new feature in JMP 16.
