rleeper
How to use the SQL LIKE ANY command?
Hi all.
I am trying to use the input from a text box to have a SQL query that uses the LIKE command, but with multiple entries.
Getting the list out of the text box is easy, the problem comes when I try a SQL query with LIKE and a list.
id = {"R8D-304%","R8D-404%","R8D-515%"};
Select WHERE Serial LIKE ANY (????)
This is where I have problems.  I've used the Concait Items when searching for a list of exact matches, but I need to find any close matches.
pmroz
Re: How to use the SQL LIKE ANY command?
Couldn't resist - you can do it with CONCAT ITEMS:
sql_statement = "SELECT WHERE serial LIKE '" || concat items(id, "' OR serial LIKE '") || "'";
pmroz
You can't combine an IN LIST with LIKE.  You could build a series of OR statement like this:
for (i = 1, i <= nitems(id), i++,
     one_item = id[i];
     if (i == 1,
           sql_statement = evalinsert("SELECT WHERE serial LIKE '^one_item^'");
           sql_statement = evalinsert("^sql_statement^ OR serial LIKE '^one_item^' ");
show(sql_statement);
sql_statement = "SELECT WHERE serial LIKE 'R8D-304%' OR serial LIKE 'R8D-404%'  OR serial LIKE 'R8D-515%' ";
pmroz
rleeper
PMroz, the second answer works perfectly!  I had to adjust it to compensate for the column not always being named serial depending on the table but the query is exactly what I needed.
Thanks.
