lwx228
How to use "Join" function to join the second table directly to the right of the first table?
I tried this command to be able to splice, but generated a new table.
dt=dt<<Join(With(d1),By Row Number, Output Table("Join"));
How to use the "Join" function to join the second table directly to the right of the first table without generating a new table.
The table of the image is illustrative and has no practical significance.
Thanks!
Re: How to use "Join" function to join the second table directly to the right of the first
Use:
     Tables==>Update
