anne_sa
Feb 24, 2016
How to use RunProgram with an external program based on a server?
Hello everybody,
I would like to know how I can call an external program stored in a server, with the RunProgram function.
I tried something like this:
RP = RunProgram(
    Executable(  "\\MyServer\SharedFolder\Program.exe"  ),
But I get the following error in the log:
"The network name cannot be found."
Does anybody have already done something like that?
Thanks in advance for your help!
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: How to use RunProgram with an external program based on a server?
Thanks, @anne_sa, that's significantly more complicated.
Run Program() will run programs on the local machine, so you'll need to find some program on the local machine that will connect to the remote machine (server) and execute the program you want to run. JMP doesn't have anything built-in to do that.
Perhaps you could use Telnet for this but I'm not an expert with that.
-Jeff
Jeff_Perkinson
Community Manager
Jun 23, 2011
Can you clarify a bit?
Do you want the program to execute on the server?
Or, is the executable stored on a fileserver and you want to run it on the same computer as JMP by mounting that drive?
-Jeff
anne_sa
Feb 24, 2016
Jeff,
It is the first option: I would like to execute the program on the server.
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
anne_sa
Feb 24, 2016
Ok Jeff so I'll try to do something like this and have a look at Telnet.
Thank you very much for your answer!
