How to use JSL to select a specific item in the filter
Hi all,
I would like to ask how to use JSL to select a specific item in the filter when the local data filter already exists, such as first selecting :age == "12" and then selecting :age == "13" next time,thanks (JMP17)
Re: How to use JSL to select a specific item in the filter
Sending Where message to data filter is one option. Scripting Index has example on how to use it
dt = Open("$SAMPLE_DATA/Cities.jmp");
obj = dt << Data Filter(Add(Filter Columns(:Region, :Lead)));
Wait(1);
obj << (Filter Column(:Lead) << Where(:Lead >= .4 & :Lead <= 1.4));
6 REPLIES 6
Wait(1);
Sorry, I forgot to add one condition — it was in the Graph Builder and I just tried it out, but it doesn't seem to have taken effect.
What does your script look like? Do you have reference to the local data filter?
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
graph = dt << Graph Builder(
	Size( 528, 455 ),
	Show Control Panel( 0 ),
	Variables( X( :POP ), Y( :CO ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 5 ) ) ),
graph << Local Data Filter(
	Add Filter( columns( :Region ), Display( :Region, N Items( 6 ) ) )
//It seems that writing it this way doesn't work, obj << (Filter Column(:Region) << Where(:Region == "C"));
It is hoped that the selection of filters can be separated for independent operation.
	Size(528, 455),
	Show Control Panel(0),
	Variables(X(:POP), Y(:CO)),
	Elements(Points(X, Y, Legend(3)), Smoother(X, Y, Legend(5)))
ldf = graph << Local Data Filter(Add Filter(columns(:Region), Display(:Region, N Items(6))));
ldf << (Filter Column(:Region) << Where(:Region == "C"));
hhh, I was so careless. Thank you for your patient answers.
