lwx228
How to use JSL to produce Chart that are grouped together for display?
Just like the in the Chart
Thanks!
dt << New Column( "r", formula( If( Row() == 1 | :age != Lag( :age, 1 ), 1, Lag( :r, 1 ) + 1 ) ) );
dt << run formulas;
Column( "r" ) << deleteFormula;
dt << Graph Builder(
	Show Control Panel( 0 ),
	Show Legend( 0 ),
	Variables( X( :r ), Y( :weight ), Group Y( :age ) ),
	Elements( Line( X, Y, Legend( 1 ), Summary Statistic( "Sum" ) ) )
Re: How to use JSL to produce Chart that are grouped together for display?
Is this the chart you are looking for?  If so, just remove Age from the Y grouping and then make Age an Overlay variable and save the script
lwx228
Thank Jim!
