JackGu
How to use JMP plot circular(wafer position)
Hi all,
Is it possible to use JMP to plot circular data (wafer position) based on the Excel data points provided in the attachment?
please provide me JMP scrip file or Built-in function. Thank you.
Re: How to use JMP plot circular(wafer position)
I think you have to script that and you cannot directly add legend to graph box
nw = New Window("Example",
	H List Box(align("center"),
		Graph Box(
			Frame Size(500, 500),
			XAxis(Min(-175), Max(175), Inc(25), Show Major Grid),
			YAxis(Min(-175), Max(175), Inc(25), Show Major Grid),
			XName("x"),
			YName("y"),
			Pen Size(3);
			Pen Color("Black");
			Circle({0, 0}, 150);
			Pen Color("Red");
			Circle({-1.865, 7.892}, 150);
		Lineup Box(N Col(1),
				Spacer Box(Size(30, 3), Color("Black")),
				Spacer Box(Size(1, 0)),
				Text Box("Black item")
				Spacer Box(Size(30, 3), Color("Red")),
				Text Box("Red item")
Write();
In Graph Builder you might have some other options
9 REPLIES 9
Or you can use graphic scripts https://www.jmp.com/support/help/en/18.1/#page/jmp/graphics-functions.shtml?os=win&source=applicatio...
Edit: Example script for graph box
	Graph Box(
		XName("x"),
		YName("y"),
		Pen Size(3);
		Pen Color("Black");
		Pen Color("Red");
JackGu
Hi jthi,
Thank you very much for your feedback.
Metod 1:
Could you provide more detail steps for me, I can't plot like you.
Metod 2:
The plot appears to be perfect, but I encounter an issue when attempting to add a trend line (Actual position/ Current position). Could you please assist me in resolving this problem? Thank you.
	Graph Box(
		XName("x"),
		YName("y"),
		Pen Size(3);
		Pen Color("Black");
		"100",
			ScaleBox,
			{Legend Model(
				4,
				Properties(
					0,
					{Line Label Properties( {Name Label( 1 )} )},
					Item ID( "Actual position", 1 )
		Pen Color("Red");
		"100",
			ScaleBox,
			{Legend Model(
				4,
				Properties(
					0,
					Item ID( "Real position", 1 )
Thank you very mauch.
In your image, you might have your data in character (or at least nominal/ordinal) format, try changing it to numeric continuous.
JackGu
Hi jthi,
Thank you for your help,
Solution 1: [Done]
Solution 2:
Where and what command need add in the script as you provide.
Thank you very much.
Warm Regards,
Jack Gu
How do you wish to compare them?
JackGu
Hi jthi,
In Solution 2 (Script Method), I would like to inquire about the process of adding a red circle to denote the "current position" and a black circle to indicate the "actual position" on the plot, as shown in the attached image. Could you please specify the necessary commands and their appropriate placement within the script? Thank you for your assistance.
Warm Regards,
Jack Gu
So you wish to have legend not trend line?
		Graph Box(
			XName("x"),
			YName("y"),
			Pen Size(3);
			Pen Color("Black");
			Pen Color("Red");
Write();
JackGu
Hi jthi,
 Thank you for your assistance. I would like to summarize the solution and provide convenience for others who may encounter the same issue.
Solution 1:
Solution 2:
		Graph Box(
			XName("x"),
			YName("y"),
			Pen Size(3);
			Pen Color("Black");
			Pen Color("Red");
Write();
Warm Regards,
Jack Gu
