BookmarkSubscribe
richard0
How to use ApproxStdErr from Nonliear model in a Tukey analysis?
I am using a 4p nonlinear model to get the inflection points of curves defined by my data, theta4.  I would like to then run something like a Tukey analysis to determine if there are significant differences between these inflection points.  I have been looking for a way to pass the ApproxStdErr from the 4p model but have not found a solution.  It seems to me that this should be a fairly common situation and would appreciate any guidance in how it should be solved.
KarenC
Re: How to use ApproxStdErr from Nonliear model in a Tukey analysis?
Richard,
If you are fitting your models using the non-linear platform with a grouping variable for your different "groups" then there is an option called compare estimates that utilizes Analysis of Means to compare the parameter estimates across the groups.
Karen
KarenC
Richard,
Karen
richard0
Thanks Karen, that was what I was looking for.
