BookmarkSubscribeRSS Feed
How to superimpose multiple histograms?
Hi Guys,
How can I superimpose two or more histograms in one window? I have some data with one set of limits and another set of data with other limits which are close (not that different) and I would like to plot both the datasets on one histogram chart and showing the two different sets of limits.
Thanks.
mpb
Jun 23, 2011
Re: How to superimpose multiple histograms?
Will this example do?
Open the fitness data and add spec limit column properties to both. I arbitrarily chose 150 and 190 for RunPulse, and 155 and 195 for MaxPulse.
That worked, thanks.
Is there any way to append the two histograms on the same chart with different colors?
mpb
Jun 23, 2011
Do you mean two overlapping histograms on the same axis? If so, play around with
1) Right clicking the bars to change the bar color for one or both
2) Right clicking the bars to change the bar transparency for one or both
3) Right clicking one set of bars to Edit>Copy Frame Contents
4) Right clicking the other set of bars to Edit>Paste Frame Contents
