lehaofeng
How to solve program errors——Limit Column Detect( 1 )
我的程序本来是正常的,只是花费时间比较大多,大概两分钟运行时间。为了节省时间,我将Limit Column Detect( 0 )改为Limit Column Detect( 1 ),程序就出错了,算的值和原来不一样,请问如何避免。
Jeff_Perkinson
Re: How to solve program errors——Limit Column Detect( 1 )
I'm afraid I'm having difficulty understanding what has gone wrong.
However, the option you changed, Limit column type detection, has likely resulted in the data type for one of your columns to change from Numeric to Character, or the other way from Character to Numeric. This can drastically change the analysis options that result from using this column.
You should look at the data table that you get with and without that option set to see which column(s) has a different data type, and determine which is the correct data type.
-Jeff
I cannot find a reference to Limit Column Detect.  Could you provide the complete script or at least more of the code where Limit Column Detect is referenced?
lehaofeng
//热轧部分
rz01 = Open(
    "$DESKTOP/热卷存货明细.xls", //热轧明细表
    Worksheets( "热卷存货明细" ),
    Use for all sheets( 1 ),
    Concatenate Worksheets( 0 ),
    Worksheet Settings(
        1,
        Has Column Headers( 1 ),
        Headers Start on Row( 1 ),
        Data Starts on Row( 2 ),
        Data Starts on Column( 1 ),
        Data Ends on Row( 0 ),
        Data Ends on Column( 0 ),
        Replicated Spanned Rows( 1 ),
        Suppress Hidden Rows( 1 ),
        Suppress Hidden Columns( 1 ),
        Suppress Empty Columns( 1 ),
        Treat as Hierarchy( 0 ),
        Multiple Series Stack( 0 ),
        Import Cell Colors( 0 ),
        Limit Column Detect( 0 ),
rz01:材料状态码 << Data Type( Character ) << Set Modeling Type( "Nominal" );
rz01 << Move Selected Columns( {:材料实际长度}, after( :WG封锁原因代码 ) );
rz01 << Clear Select << Select Rows( N Rows( rz01 ) ) << Delete Rows; //
rz01 << New Column( "厂别",
    Formula(
        If(
            Substr( :材料号, 2, 1 ) == "2", "热轧厂",
            Substr( :材料号, 2, 1 ) == "3", "热轧厂",
            Substr( :材料号, 2, 1 ) == "4", "CSP",
            "错误"
rz01 << Move Selected Columns( {:厂别}, after( :Column 1 ) );
rz02 = Open(
    "$DESKTOP/热卷申报明细.xls", //申报明细表
    Worksheets( "热卷申报明细" ),
    Worksheet Settings(
        1,
rz02 << New Column( "类型2",
    Formula(
        If(
            Substr( :现货申报编号, 1, 3 ) == "IQK", "已QK寻源",
            :现货申请类别 == 2, "已QC寻源",
            "已申报现货"
rz02:材料号 << Data Type( Character ) << Set Modeling Type( "Nominal" );
rz03 = Open( "$DESKTOP/留用明细.jmp" ); //留用明细表
rz03 << Row Selection( Select where( Is Missing( :留用原因 ) ) ) << delete row()
 << run forground; //删除符合条件的行
//连接表
rz04 = rz01 << Join(
    With( rz03 ),
    Select( all ),
    SelectWith( :材料号 ),
    By Matching Columns( :材料号 = :材料号 ),
    Drop multiples( 0, 0 ),
    Include Nonmatches( 1, 0 ),
    Preserve main table order( 1 )
Close( rz01, nosave );
Close( rz03, nosave );
rz04:"“热卷存货明细”中的“材料号”"n << Set Name( "材料号" );
rz04:材料号 of 留用明细 << Delete Property( "Aliases" ) << Set Name( "一事一议" );
rz04 << Move Selected Columns( {:一事一议}, after( :材料状态码 ) );
rz05 = rz04 << Join(
    With( rz02 ),
    Select( all ),
    SelectWith( :类型2 ),
Close( rz02, nosave );
Close( rz04, nosave );
//生产现货类型列,按照余材原因代码
rz05 << New Column( "现货类型",
    Formula(
        If(
            Length( :WG余材原因代码 ) == 8, "质量原因",
            Length( :WG余材原因代码 ) == 0, "质量原因",
            Contains(
                {"8C", "8G", "8R", "8Y", "9C", "82", "87", "90", "91", "92",
                "93", "95", "96", "97", "99"},
                :WG余材原因代码
            ), "生产原因",
            Contains(
                {"0H", "00", "8B", "8Z", "9A", "9B", "9D", "9E", "9F", "11",
                "12", "13", "14", "24", "70", "77", "84", "94", "98"},
                :WG余材原因代码
            ), "质量原因",
            "错误"
rz05 << Move Selected Columns( {:现货类型}, after( :一事一议 ) );
I am finding that you have a column reference incorrectly specified.  Your column specification is
rz04: "Material No." in "Hot Coil Inventory Details""n
and it should be
rz04:"\!"Material No.\!" in \!"Hot Coil Inventory Details\!""n
lehaofeng
However, this program can run normally without error. Is this writing wrong?
Jeff_Perkinson
-Jeff
