How to set a Reference Line on each page with Page option in Graph Builder?
Neo
Neo
The following script plots some charts with the page option in graph builder? How to I set a horizontal reference line, for each chart, say at Weight = 80Kg and label it (80kg) using JSL?
(I need the reference line to remain even if there is a change in the number of charts plotted)
dt = open("$SAMPLE_DATA/Big Class.jmp");
gb = dt << Graph Builder(
	Size(528, 2954),
	Show Control Panel(0),
	Variables(X(:height), Y(:weight), Page(:age)),
	Elements(Points(X, Y, Legend(15)), Smoother(X, Y, Legend(16)))
Re: How to set a Reference Line on each page with Page option in Graph Builder?
And graphic script might be an option
	Size(528, 984),
	Elements(
		Points(X, Y(1), Legend(15)),
		Smoother(X, Y(1), Legend(16))
(Report(gb) << XPath("//FrameBox")) << Add Graphics Script(
	Pen Color("Red");
	Text Color("red");
	Text(Right Justified, {X Origin() + X Range(), 80}, "Reference");
	H Line(80);
gb << Local Data Filter(
	Add Filter(
		columns(:age),
		Display(:age, N Items(6))
Write();
10 REPLIES 10
	Size(528, 2954),
axis = gb << XPath( "//AxisBox" );
Summarize( page = By( :age ) );
axis[2::(2*NItems( page ))::2] << Add Ref Line( 80, "Solid", "Red", "Reference" );
Neo
Neo
@Mark_Bailey  Stops working for me (JMP 16.2) if I invoke Local Data Filter on Age after plotting, as below
Easiest way is to add new column to your data table with same value for each of the rows and add that to your graph. This will work with filters
Neo
Neo
@jthi your suggestion works fine, except that I would like the line label to be on the right. Is there a way to change the location of the line label?
I don't remember which options are available in JMP16 as I'm mostly using JMP18 nowadays (with some JMP17 mixed in)
dt << New Column("Ref", Numeric, Continuous, Set Each Value(80));
	Size(528, 984),
	Variables(X(:height), Y(:weight), Y(:Ref, Position(1)), Page(:age)),
	Elements(
		Smoother(X, Y(1), Legend(16)),
		Line(Y(2), Legend(17))
	Local Data Filter(
		Add Filter(
			columns(:age),
			Where(:age == {12, 15}),
		Dispatch({}, "400", ScaleBox,
			{Legend Model(
				17,
				Level Name(0, "Ref", Item ID("Mean(Ref)", 1)),
				Properties(
					0,
					{Line Label Properties(
						{Name Label(1), Name Label Position("Last")}
Write();
Level XII
No need to change the data table.
Replicating the axis setting via
Link Page Axes( "Y Only" )
copies the reference lines as well.
e.g.
Graph Builder(
	Link Page Axes( "Y Only" ),
	Variables( X( :height ), Y( :weight ), Page( :sex ), Overlay( :sex ) ),
	Elements( Points( X, Y), Smoother( X, Y) ),
		Dispatch( {}, "weight", ScaleBox,
			{Add Ref Line( 100, "Solid", "Black", "", 1 )}
That is also an option, but you do lose one of the benefits of Page: having different axis scaling for different "pages". It might not be an issue here and might be even a benefit.
Neo
Neo
@jthi Thanks.
does not seem to be available/ working in JMP 16.2.
@hogi Reason for me choosing the Page option is so that I can get different y-axis scaling. I am sure there are other ways of doing this, but Page option seems easiest.
Then you might have to go back to Mark's solution and use filter change handler with it. Again no idea what are the limitations of JMP16 with this option
	Size(528, 984),
	Elements(
	Local Data Filter(
		Add Filter(
			columns(:age),
add_reflines = EvalExpr(
	axis = Expr(gb) << XPath("//AxisBox");
	axis[2::N Items(axis)::2] << Add Ref Line(80, "Solid", "Red", "Reference", 1, 1, Label Settings({Opposite Axis(1)}));
f = Function({a}, add_reflines);
ldf = (Report(gb) << top parent)[OutlineBox("Local Data Filter")] << Get Scriptable Object;
rs = ldf << Make Filter Change Handler(f);
add_reflines;
Write();
This isn't the most robust option to do this, but it is fairly simple one.
