BookmarkSubscribeRSS Feed
ba
Oct 22, 2013
How to save a matrix formula into data table?
Does any of you know how to use JSL to save a matrix formula into data table, such as ([1] || (X1 + 1))* [2, 3] ?
Directly typing it in the formula editor works. But using JSL, it doesn't allow me to save any expression into matrices/vectors.
For example, Concat(1,Expr(X1+1)); is invalid.
I’ve also tried to save the expression into a list first and then multiply it with a numerical vector/matrix. But JSL complains that the lists and matrices cannot be mixed together in the formula.
Have you encountered any JSL example that can save such formula expressed in vectors/matrices? Many thanks in advance!
ba
Oct 22, 2013
Solution
Re: How to save a matrix formula into data table?
I've just learned from Ryan Lekivetz the following script which works great!
myexp1 = nameexpr( ([1] || X1 + 1) * [2,3]);
dtt=current data table();
Eval(Substitute(
Expr(dtt << New Column("formula1 ",<<Formula(__form1__))),
Expr(__form1__), Eval Expr(myexp1),
One surprising thing I've found is that the JMP profiler doesn’t recognize such matrix formulas. For example, typing (:X1 || :X2 ) * [2, 3] or 2*:X1+3*:X2 in the formula editor could yield exactly the same result in the data table, but the profiler doesn’t recognize the first version. This may be a bug for the profiler.
ba
Oct 22, 2013
Solution
Eval(Substitute(
