ENTHU
How to save a list to a csv?
Trying to save a list to a column in csv.How to do this?
Tried the follwoing code but doesnt seem to work-
name = {};
name =Name1||"_"||Name2;
Macrodt=New Table("table1",
New Column("name",
Character,
Nominal
Set Values( {name [1]})
invisible
Re: How to save a list to a csv?
You are setting the variable name to be a list
name = {}'
But then you set it to be a string variable
name = Name1 || "_" || Name2.;
So name is no longer a list.
Below is a modification to your code that does what I think you want
name = {};
name1 = "a";
name2 = "b";
name[1] = Name1 || "_" || Name2;
Macrodt = New Table( "table1",
	New Column( "name", Character,
	Nominal, Values( Eval( name ) ) )
name = {}'
name = {};
name1 = "a";
name2 = "b";
pmroz
A common mistake is to use the same name for a variable and a column.  Your list is called name, and you are defining a column called name.  Try this code instead.  I removed invisible so you can see the result.
name1 = "a";
name2 = "b";
name_list = {};
name_list[1] = Name1||"_"||Name2;
	New Column("name", Character, Nominal, Set Values( name_list) ),
Article Labels
