yanee
How to save Contour Profiler from the Least Square Model
How can we save only contour profiler from the least square model into separate window ?
Re: How to save Contour Profiler from the Least Square Model
The way I would do it is to
  1. Run the Least Squares analysis
  2. Save the Predicted Formula
  3. Run the Profiler Platform and point it to the saved Prediction Formula
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
fm = dt << Fit Model(
	Y( :height ),
	Effects( :age, :sex, :sex * :age ),
	Emphasis( "Effect Leverage" ),
	Run(
		Profiler(
			1,
			Confidence Intervals( 1 ),
			Term Value(
				age( 12, Lock( 0 ), Show( 1 ) ),
				sex( "F", Lock( 0 ), Show( 1 ) )
		:height << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
		Parameter Estimates( 1 ), Lack of Fit( 0 ), Scaled Estimates( 0 ),
		Plot Actual by Predicted( 1 ), Plot Regression( 0 ),
		Plot Residual by Predicted( 1 ), Plot Studentized Residuals( 0 ),
		Plot Effect Leverage( 1 ), Plot Residual by Normal Quantiles( 0 ),
		Box Cox Y Transformation( 0 )}
fm << prediction formula;
dt << Profiler(
	Y( :Pred Formula height ),
	Profiler(
		1,
		Term Value(
	Custom Profiler(
		1,
		Term Value(
		Objective Formula( :Pred Formula height )
	SendToReport( Dispatch( {}, "Custom Profiler", OutlineBox, {Close( 1 )} ) )
