Thomas1
Level V
How to run the function "Columns Viewer" with JSL
Is there a way to run the function "Columns Viewer" from the menu Cols => Columns Viewer by JSL?
I'd like to do this in order automate a work flow with data gathered by the Columns Viewer.
Re: How to run the function "Columns Viewer" with JSL
Here is how to access it
dt = Current Data Table();
Main Menu( "columns viewer" );
Thomas1
Level V
Hi Jim,
Thanks for your fast reply. This code is very easy and helpful.
