dmw1
How to remove fill patterns from graph builder figures
I recently tried to use the fill pattern with a graph builder figure I was working on.  Now I can't see to remove it and it's showing up in other GB figures that I had not intended to use any fill patterns.  This has turned into a bit of a nightmare.
Please if anyone has an idea of how to deal with this I'm all ears.
Thanks,
DMWard
stan_koprowski
Re: How to remove fill patterns from graph builder figures
Right-cllick the legend for each level you want to change and select the solid pattern on the bottom right and press the OK button to apply your changes.
Best,
Stan
dmw1
Hi Stan,
  It appears that your drop down has a solid (no pattern) choice where I dont see that with mine.  I found out inadvertently that to undo the pattern I need to click on the legend item in the graphic.  So Im set, got it figured out, but thanks.
DMW
