pmroz
How to remove col boxes from a tablebox?
I'm using col boxes inside of table boxes to contain buttons.  Very convenient way to have buttons, checkboxes, etc. inside a grid.  The problem I'm having is that when I go to refresh the tablebox with new values the col boxes stubbornly hold on to their old values.
The code below demonstrates the behavior:
old_nr = 0;
nw = new window("Test col box removal",
    hlistbox(,
        textbox("Enter # rows: "),
        neb = number edit box(),
    button box("Refresh rows",
        for (i = old_nr, i > 0, i--,
            tbl_box << delete row(i);
        c1_list = {};
        n1_list = {};
        cb_list = {};
        nr = neb << get;
        old_nr = nr;
        for (i = 1, i <= nr, i++,
            c1_list[i] = char(i);
            n1_list[i] = i;
            cb << append(button box(char(i)));
        c1 << set values(c1_list);
        n1 << set(n1_list);
    tbl_box = table box(
        c1 = string col box("C1", {}),
        n1 = number col box("N1", {}),
        cb = col box("CB", {}),
ms
Super User ms
Re: How to remove col boxes from a tablebox?
Seems to be easiest to delete the old Col Box() entirely and append a new one for each update.
Does this behave the way you want?
nw = New Window("Test col box removal",
    H List Box(, Text Box("Enter # rows: "), neb = Number Edit Box(), ),
    Button Box("Refresh rows",
        c1_list = {};
        n1_list = {};
        cb_expr = Expr(Col Box("CB"));
        nr = neb << get;
        For(i = 1, i <= nr, i++,
            c1_list[i] = Char(i);
            n1_list[i] = i;
            Insert Into(cb_expr, Button Box(Char(i)));
        n1 << set(n1_list);
        cb << delete;
        tbl_box << append(cb = cb_expr);
    tbl_box = Table Box(c1 = String Col Box("C1", {}), n1 = Number Col Box("N1", {}), cb = Col Box("CB")),
ms
Super User ms
        c1_list = {};
        n1_list = {};
        nr = neb << get;
            n1_list[i] = i;
        n1 << set(n1_list);
        cb << delete;
pmroz
Thanks MS that's one wrinkle I didn't try.  The COL BOX object doesn't behave the same way as a string col box or number col box
