BookmarkSubscribeRSS Feed
jason_paquette
Jan 26, 2015
How to reference and act on a dynamically created ListBox?
I needed to build a GUI that was capable of adding and removing ListBox entries with a simple button click.
I managed to figure out how to add ListBox/button (wrapped in an HListBox) pairs dynamically using the script below, but I am not sure how to reference them for the delete button.
NewWindow("WINDOW_NAME", << Modal,
OutlineBox("OUTLINE_NAME",
  test_lb = VListBox(
   ButtonBox("Add",
    test_lb << Append(
     HListBox(
      OutlineBox("TEST_INSTANCE_" || Char(Today())),
      ButtonBox("Remove" //somehow remove only the current HListBox object
   ButtonBox("OK")
Wendy_Murphrey
Jun 23, 2011
Solution
Re: How to reference and act on a dynamically created ListBox?
Hi, Jason.
The following example demonstrates how to use a function to self-reference the ButtonBox and then delete the parent in the Remove button:
New Window( "WINDOW_NAME",
  <<Modal,
  Outline Box( "OUTLINE_NAME",
       test_lb = V List Box(
            Button Box( "Add",
                 test_lb << Append(
                      H List Box(
                           Outline Box( "TEST_INSTANCE_" || Char( Today() ) ),
                           Button Box( "Remove", <<Set Function( Function( {this}, (this << Parent) << Delete ) ) )
            Button Box( "OK" )
I hope that helps!
Wendy
Wendy
jason_paquette
Jan 26, 2015
Working at this a bit longer, I figured the only way to do this was to give each box a dynamic index using Eval(Parse(EvalInsert())) commands.
There might be a better way to do it, but this seemed to work for me.
test_inst = 0;
  test_lb = VListBox(
   ButtonBox("Add", test_inst += 1;
    Eval(
     Parse(
      EvalInsert("
       test_lb << Append(
        test_inst_lb_^test_inst^ = HListBox(
         OutlineBox(\!"TEST_INSTANCE_\!" || Char(^test_inst^)),
         TextBox(Char(^test_inst^)),
         test_inst_bb_^test_inst^ = ButtonBox(\!"Remove\!",
          Print(<<GetPropertyList);
          test_inst_lb_^test_inst^ << Delete;
   ButtonBox("OK")
Wendy_Murphrey
Jun 23, 2011
Solution
Hi, Jason.
  <<Modal,
            Button Box( "Add",
                 test_lb << Append(
                      H List Box(
            Button Box( "OK" )
I hope that helps!
Wendy
Wendy
