Theresa
How to realize search 3 column, if there is any column>100, then add new column fill in with "1"
How to realize search 3 columns in the table, and if column "age, height,  weight" any row value in same column value>100, then add new column name "Mark" fill in with "1", others NA.
Final result i want:
Re: How to realize search 3 column, if there is any column>100, then add new column fill in with "1"
It is a simple script to handle what you want.  Here is a formula to that can be specified for your column called Mark
If(:age > 100 | :Height >100 | :Weight > 100, 1, .)
