BookmarkSubscribeRSS Feed
man
Jun 23, 2011
How to put repeated measurements of SEVERAL GROUPS on the SAME plot?
I measure the Y value of the three groups.
The measurements were repeated three times (in different conditions).
I want to bring them on ONE plot!
Using "Fit Y by X" we get three (the number of repeated measurements) columns on the graph, and 5 groups points will be mixed (in each measurement).
I would like them (groups) to were located next to each other (using the auto legend to color/mark not enough, because the groups point are mixed and overlapped (in each measurement)).
This is easily done by OVERLAY PLOT, but there will have to encode 1,2,3, ... 15 on the X-axis in a complate graph (and this sequence can not be edited in performe graph in JMP, unfortunately), but I need 1,2,3,4,5, 1,2,3,4, 5, 1,2,3, 4, 5 on the x-axis.
Thank you in advance.
pmroz
Jun 23, 2011
I'm having trouble understanding what your data looks like.  Can you post some sample data?
ms
Jun 23, 2011
You can do it with Graph Builder (JMP8 or 9) or Variability Chart. See script example below
// make sample table
dt=New Table( "Several groups on same plot",
          Add Rows( 15 ),
  New Column( "Repeat",
                    Numeric,
                    Nominal,
                    Format( "Best", 12 ),
                    Set Values( [1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3] )
  New Column( "Item",
                    Numeric,
                    Nominal,
                    Set Values( [1, 2, 3, 4, 5, 1, 2, 3, 4, 5, 1, 2, 3, 4, 5] )
  New Column( "Data",
                    Numeric,
                    Continuous,
                    Set Values( [15, 13, 1, 12, 2, 4, 14, 14, 9, 2, 4, 1, 7, 2, 14] )
// Graph builder
dt<<Graph Builder(
          Variables( X( :Item ), Y( :Data ), Group X( :Repeat ) ),
          Elements( Points( X, Y, Legend( 1 ) ) )
//Variability chart
Variability Chart(
          Y( :Data ),
          X( :Repeat, :Item ),
          Std Dev Chart( 0 )
