News
manny_uy
How to properly analyze the data fro popcorn example in JMP's sample files due to unequal variances?
shoffmeister
Re: How to properly analyze the data fro popcorn example in JMP's sample files due to unequal varian
There is a in-depth description of the problem in an older version of the JMP DOE Guide
https://www.jmp.com/support/downloads/pdf/jmp_doe_guide.pdf . The popcorn example is used in the introduction chapter and documented including the analysis via GLM beginning with page 15.
Hope that helps.
manny_uy
Tried it without success. Are you using the current V12 example for popcorn.jmp? The factors and response are different from that used in an earlier version that you recommended..
