kaushik_pushpen
How to plot variability chart using data filter ?
Hello everyone,
I have one Abc.jmp table in which i am  using data filtering one by one by selecting value from the table Layer.jmp. So, after data filtering i want to plot various variabilty chart. But it is not happening. Script is as follows:
dt1 = open("F:\Abc.jmp");
dt2 = open("F:\Layer.jmp");
for(i=1, i<=nrow(dt2), i++,
     df = dt1<< Data Filter(
       Add Filter(
       columns( :Mask ),
       Where(:Mask == Eval((trim(column(dt2, 1))))),
       Display(:ParameterId, Size( 221, 259 ), List Display )
       ), make subset
          df<<Variability Chart(
            Y( :Name( "CD-value" ) ),
            X( :Axis ),
            Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
            Process Variation( 0 ),
            Show Grand Mean( 1 ),
            Std Dev Chart( 0 ),
            By(:Nominal)
Please give your valuable suggestion.
Thanks in advance.
ms
Super User ms
Re: How to plot variability chart using data filter ?
I think you'd want the index to be right after Column(), i.e. inside Trim(), not outside.
Where(:Mask == Eval(trim(column(dt2, 1)[i]))),
