BookmarkSubscribeRSS Feed
How to pass a string variable as column name in a Oneway chart?
Hi Guys,
I am trying to pass a variable name to a Y axis column name for a Oneway chart as follows:
Re: How to pass a string variable as column name in a Oneway chart?
Anybody?
mpb
Jun 23, 2011
Changing the last line to:
Oneway( Y( col ), X( :Lot Number ), Box Plots( 1 ) );
should work.
Note: When using the explicit Concat Items syntax, JSL inserts a separating character, a space by default. If you change the concat to: comb = concat Items({a,b}, "") a space will not be inserted. If instead you replace that line by the simpler: comb = concat(a,b) or comb = a || b; then no space will be inserted either.
