Robbb
How to pass a function to Parallel Assign()?
Hi everybody,
I am trying to pass a function to the local memory space of the Parallel Assign function:
F = Function( {x,y}, x+y);
M = J(2,3,0);
Parallel Assign({F=F},M[i,j]=F(i,j));
M;
It does not work because JMP tells me F has 2 parameters but 0 were given. How can I fix this?
Of course it is a boiled down problem of a much longer script. I could define F inside Parallel Assign, but it is unnecessary to define one and the same function in each of my n execution (n is large). Is there a way to hand over a function to Parallel Assign?
Craige_Hales
Staff (Retired)
Re: How to pass a function to Parallel Assign()?
Robbb
Thanks. So with
M = J(2,3,0); Parallel Assign( {F = Function( {x,y}, x+y)}, M[i, j] = F( i, j ) );
I can define a function once for Parallel Assign. But is it possible to do it outside the Parallel Assign statement? What if I want to use one and the same function inside and outside Parallel Assign? Do I really have to define it twice?
In general, if I have a function F, is it possible to assign the same function to G (of course without redefining it)? G=F does not work, since JMP expects the parameters of F.
