  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
lala
Level IX
How to open a SAS file in sas7bdat format using JSL?
Thanks!
  • Opening the file directly with JMP shows different results
David_Burnham
回复: How to open a SAS file in sas7bdat format using JSL?
Perhaps you need the option to use labels for the names?
dt1 = Open(
	"$SAMPLE_IMPORT_DATA/Bigclass.sas7bdat",
	Use Labels for Var Names( 1 )
-Dave
lala
Level IX
mesae1commercialdrep20220813.sas7bdat
David_Burnham
dt1 = Open(
-Dave
