News
We’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
scottahindle
How to modify quick graph x-axis in Process Screening
To a comparable question on the control chart x-axis in Process Screening I got a great answer https://community.jmp.com/t5/Discussions/How-to-modify-control-chart-x-axis-in-Process-Screening/m-p...
Is it possible to customise the x-axis for the "Quick Graph" option in Process Screening?
I have numerous parameters to process in the Process Screening Platform with just a couple having many more data than the majority. As a result, the majority of the quick graphs have an x-axis that is way longer than needed. A more informative quick graph would have the x-axis based on the number of data in scope for any given variable being assessed in the 'Process Screening' platform.
Is there any way to perform this customisation of the x-axis?
Thanks in advance for any input.
