BookmarkSubscribeRSS Feed
wunglish
Mar 15, 2016
How to mark specific data row location in its histogram?
Hello Expertise
I'd like to mark specific data row's location on its histogram as shown in below pic.
I know how to do it manually. I am looking for automatic way just by selecting or marking the data row, it marks the value position on it histogram.
Any good idea on this?
Thank you
Wung
ian_jmp
Jun 23, 2011
Re: How to mark specific data row location in its histogram?
One option is to add a reference line to the axis:
// Make a histogram of 'height'
dist = dt << Distribution( Continuous Distribution( Column( :height ) ), Histograms Only );
// Pick a random row
hVal = Column(dt, "height")[RandomInteger(1, NRow(dt))];
// Add a reference line
dist << SendToReport(Dispatch({"height"}, "1", ScaleBox, {Add Ref Line( hVal, "Solid", "Red", "", 1 )}));
You could put the line 'in front of' the histogram if needed.
wunglish
Mar 15, 2016
Hello Ian
Thank you very much. I thought there is a way without making custom script.
Anyway, this script is using random selection. Is there any way to insert dialog box which is asking to key in "name" and "sex"  and so on instead of random selection?
Thank you
JWJEONG
r23426
Jul 3, 2014
Hi
This is what I am using to get a dataset name for saving after i create it.
It should give you some direction on how to do in your case:
// get dataset name after files stacked
New Window("Text Edit Box",
                <<Modal,
                V List Box(
                            Text Box("\!r Enter a dataset name:\!r\!r"),
                            str1=Text Edit Box("Data_stacked"),
                            Text Box ("\!rSelect if data are:\!r"),
                            Panel Box("",
                                        rb_box1 = Radio Box( {"Site level", "Wafer level"} )
                            Text Box ("\!r\!r")
                Button Box("OK",
                            dataset_name = str1 << Get text;
                            data_type = rb_box1 << Get ;
show(dataset_name, data_type);
Print("dataset name will be:" || dataset_name); // returns variables after window closes
